1 - 11 of 11 Posts
I've been averaging 12.2 city driving EASY on my 2500 Ram. If I'm heavy on it, I drop to 9-10 mpg.
I filled up the other day, driving EASY and I'm averaging 14.1 mpg...WTF??? I only have 900+ miles on it, so I hardly think it's max'ed its break-in period.
I live in flatland Michigan and the only fuel this truck has known is premium. The ONLY difference is, I did go to a different gas station the other day; I would hardly think fuel would be a factor...but then again...(???)
Anyone have a clue???
· Tape On
I wouldn't doubt that a better load of fuel could affect the milage. Are you using the overhead confuser or are you calculating it by hand?
Both. I'm going back today to fill up and see if that 14.1 is correct. It'll be close just by eyeballing where the gas gauge is. Usually I'm down to just about 1/2 tank by Saturday; I have just about 3/4 tank on the same mileage. (I just drive back and forth to work with it...that's pretty much it).
Gas brands can make a differance. The wifes 1500 can vary 2-3 mpg. Both our manuals say to use reg grade, I switch to the good stuff when pulling the fifth wheel, and even there I am not sure if it makes a diff.
· 5 Years... 6 Dodges
Hang on... so you're complaining about getting the better mileage?
Gas brands can make a difference... and while they say the levels can to, I'm not tottally conviced on that because on my 03 I only put in regular and got that kind of mileage around town not taking it easy...
That's cause Air Ram sneaked up your way and installed 4.56s while you were ZZZZZZZZZZZZZZZZZZZZ :D
345 Cubic Inches of Romping, Stomping Hemi Magnum 5-speed Automatic
10.5" Trac-Lok rear end with 4.10 gears
:huh: :D
Sounds like your 2500 has two too many cylinders in addition to burning the wrong type of fuel. :D :cool:
Greg
Discussion Starter · #11 ·
THAT was hilarious!!!
1 - 11 of 11 Posts
