Change to 20w50 full syn if it is that hot there. Or better yet, deisel oil 15w40 or 5w40 full syn. The deisel oil has more anti-wear additives and more cleaning agents added from what I have gathered. I read an article in Motor Trend where they asked like 5 oil company test people, if they could only use one oil, what would it be- they all said deisel oil. I have also used Lucas Lube with great results. In a 88 ford ranger w/300,000+ miles on it. Engine was starting to clatter and trans(5-speed stick) was getting real notchy. Used gear oil in the trans and the reg stuff in eng-both problems disappeared. Also have it in our 6-speed manual in our new PW. The truck would not shift good until 10-15 miles down the road-like the atf+4 was so thin it dripped completely off the metal overnight, making it VERY difficult to shift. Drained out 6.5 qts and refilled w/3.5qts of atf+4 & 3 qts of Lucas Lube 140 gear oil, now it shifts great-even in the winter.
