I have a '95 Ram 1500 5sp. In '04, the engine blew at about 125k. Just minutes to the engine blowing, I noticed the oil gauge drop to 0 and then rebound several times to 40+. I was told by the stealership when it was towed in that the screen was clogged with garbage and that it blocked the pump, thus blowing the engine. It almost completely devoured itself from the inside. I thought at that time it was because I take the train to and from work everyday, trying to take care of the environment and saving $$$, so it sat for days without having to take it anywhere. I had to have a complete new engine put in with as little as possible from the previous one stuck on it. It is now at approximately 145k and while I was hunting this last weekend the gauge started doing it again. I noticed while limping home I could keep the pressure up by staying in the high end of 4th, but by the time I got home it had to be in the high end of 3rd. After giving some major thought on what the common factors were in the engine blowing the last time and what was going on now, I have come to the conclusion that it is one of the following; the oil place that I take it to, the oil place is not changing the oil filter like they say they are, it is the proprietary oil drain plug that the oil place put in it (Stupid of me to let them sell me on that one, I know), or the stealership didn't put in a crate engine like I asked and used as much as they could scavenge off of the blown engine. I need to get the thing in to a shop, but am a little leary at this point.
I have been reading up on this problem on other sites, but need some input from others that have had this problem and what the cause is. Some posts suggest that it could be the oil filter, the gauge, sound system, and other things that seem a bit more remote or even laughable.
Any help I could get from everyone here would be appreciated.
:help:
:help:
