1 - 2 of 2 Posts
have 04 strat w 2.7. have noticed very minor oil leak for a while but seems to be getting worse little by little . so slow , cant seem to locate scource.
common problem? does oil filt have a bolt on attachment neck? Pan gasket
a weak point ? main seals? or what
Moose
i have a 01 2.7 and I had a leak and had to have the oil pan gasket replaced under warranty. I would get the car up on ramps and wipe it all down and then see if it comes back. Also I would put carboard under the engine area and then see if anything drips on it and withot removing the carboard trace the drip back up and that should narrow it down a bit
1 - 2 of 2 Posts
