1 - 2 of 2 Posts
On my 2005 Ram 2500 there is a sticker under the hood saying to grease the front driveshaft every oil change.
I cannot find any grease zirks on the ujoints.
What am I missing?
It's there.It's on the t case side of the front driveshaft the double joint .You have to rotate the shaft and look inside the joint use a flashlight,and You will see the spot where You insert the NEEDLE to grease it.Good luck.Rob.
1 - 2 of 2 Posts
