I think it's the lack of bandwidth we have over here, I'm lucky to be able to get on the board at all as most forums are blocked by DOIM.
on topic: the fabteck spindles that came with the lift kit are much beefier & are cut different than stock units. I had clearance problems with the OEM 16" wheels mounted. The tolerance between the upper spindle area (near the ball joint) and the inner bead area of the wheel was so close I had to shave down the spindle a bit and run stick on wheel weights.
With a larger 20" tire I should have plenty of room but I'm not sure.
I don't have any pics on this computer of the spindles or I'd post them up.
Either way, I'll make em fit.
I just need to the 20s so I can get a
street tire that's between 33-35" tall by 10 - 12" inches wide, there is no such animal for a 16" wheel.
edit: shoot me an email at
[email protected]
