Does anyone else notice this with their struts? The top of the strut shaft is slightly above the surface of the mounting surface. When I jack the truck up off the ground so the wheels are at full articulation, the top of the strut shaft sinks down about 1/3 of an inch. Very odd and I am 95% positive that the hex nut is tight because I used an impact and made sure the torque was 50 or so lbs with a tq wrench.
For picture reference, I am talking about the center shaft in the middle of the 3 strut plate mounts bolts. Can anyone double check if this is normal? I don't have a logical explanation and I encourage you to see if you have this problem yourself.
