2002 dodge intrepid 2.7 is getting Bank 1 and 2 sensor 2 high voltage codes. I replaced the sensors and cleared the codes. It is still getting the same codes. I recently had an issue with the key lock cylinder which when replaced made my windows, air, signal lights, and wipers all work again. every now and then they stop working until i jingle the keys then they all work again. is there a loose wire or connection between the key cylinder and the ignition that may be causing an electrical problem thus tripping the high voltage code with the sensors? back story is that there were no codes until the cylinder messed up in the first place and i am wondering if the issues are all connected. the sensor codes all appeared while the car was off to begin with. I had the keys turned and the radio on but not running when the codes first appeared. odd that the o2 sensors would trip a code when the car was not even running.
