1 - 6 of 6 Posts
Premium Member
Today I went to do my monthly running around. You know, the bank, fill-up, get the truck detailed, and whatever. Well… it started on a sour note. I rolled the windows down it peeled the plastic off the tint on the passenger side. I had the tint replaced and then just before I got home, the engine started to get too hot. I pulled under a shade tree out front to see what was wrong; the e-fan wasn’t coming on.
I got the e-fan controller paperwork out of the glove box and then got under the hood. The e-fan controller triggers a 75-amp relay then this relay sends power from the battery to the e-fan. That way the controller never sees the heavy load from the Lincoln e-fan and the e-fan to powered directly from the battery though the large relay. The first thing I did was jumper the controller to cool the truck down. OK, with the engine cooled down, I started checking and found the problem was the controller or probe. But the strangest thing happen while I was checking the e-fan. Anytime the engine would get to the 3/4’s point, I would jumper the controller. The e-fan would come on as I held the jumper in place and as the engine would start cool and then A/C e-fan would come on. I had the A/C and blower motor turned off so this was the first strange thing. Now with the engine cool, I release the jumper but both e-fan were still running. After a minute or so, the A/C e-fan would turn off but the Lincoln e-fan was still on. The only way the fan would shut-off was if I removed the temp-jumper on the face of the controller. I let the truck continue to set until the water temp was getting to the 3/4 point, I then I would jumper the controller again with the same results. After the third time, I let the e-fan run while I pulled the truck up onto the driveway and called it day.
Personally, I’ve had it with these electrical gremlins! I’m pulling this e-fan out by the wires and putting the mechanical clutch fan back on the truck.
:jmad:
Tex
my efan came off, it wasn't doing a good enough job(for me) so its in the garage now. it took me a few days to get used to how it drove with the manual clutch fan but it is keeping cool even in traffic now.
Premium Member
I did a little checking under the hood today and found some wiring that didn't look right. I redid two of the grounds for the e-fan but still couldn't get the e-fan to come on unless I jumper-ed the controller. There's still a chance it could be the trigging relay. I have one in my toolbox so I'll try it after lunch tomorrow. Now, I’m wondering if there’s room in the shroud for the e-fan and the stock mechanical clutch fan.
:dunno:
Premium Member
Discussion Starter #4
I couldn't work in the the garage today; I had to work outside in the direct sun to do anything. My god it's hot out there! I was so over heated, I was having to ... hook-up relay and stand in the shade; put the battery in the tray and stand in the shade; hook-up battery and stand in the shade; get the tools and stand in the shade; and then ... well, you get the idea. I wanted to double-check everything because it just wasn't adding up. I rechecked the relays, ohm'ed out the probe, and did some continuity checking of the wires. As I pulled stuff apart, I cleaned and replaced connections. There was no reason why the e-fan system should not have been working.
Then I saw it! The sun light hit the probe just right. The probe was in the radiator but it was really in the radiator. When I saw it I just threw my faces up, closed the hood, and came inside. There was no way I was going to get down on the hot concert, under the hot engine, and work the probe into a hot radiator. Later, after the front of house is in the shade, and it's a little cooler outside, I'll go out there and stab the thing into fins. I'll repost when I've got it working.
:jmad:
Wow, mine is just the opposite, won't stay cool at idle with the mechanical fan, but cools fine with the E-Fan. I left the shroud in place and toss the mechanical fan back on it if I am going to do heavy towing.
Premium Member
Discussion Starter #6
That fixed it! And now the e-fan is cooling the truck even better. I thought the 12 o'clock mark on the water temp gauge was 180-degrees. After all, I had the e-fan set with the 170 jumper with a 177-Jet t-stat and the e-fan was cycling around the middle mark. I wired everything to the battery and now the e-fan even sounds stronger. I had to pull the jumper because the e-fan wasn't cycling. The e-fan was starting well before the 10 o'clock on the gauge but not turning off. So I went with the default 180-setting on the controller and the e-fan is cycling right around the 10 to 11 o'clock on the gauge. And now when I turn-off the engine, the e-fan keeps running. I like it!
:pty:
1 - 6 of 6 Posts
