I've been steady fixing little things here and there on my 89 W100. Next is the 4x4 engaged light on the dash next to the message center. The 4WD in the truck works fine, but the light doesnt at all, not in 4WD High or Low.
I checked the bulb and its good. I tried checking the two wires that go into the lights harness with a test light. I got the blue with white stripped wire to light up as a power source, thats with 4WD engaged or not. I couldnt get the green with red stripped wire to light the test light testing it as a power source or ground with the 4WD both engaged or disengaged.
I got under the truck to see what I could see in that area and found this dangling wire:
Where does this connect and could this be why my stupid little light doesnt work ?
