1 - 3 of 3 Posts
DODGETHIS
06 1500 4x4, wierd noise kinda sounds like a loose hubcap but i have wheels, kinda sounds like its from the left front but not sure, only hear it at 20mph on a not so smooth road???? takin to dealer on mon, but any ides?
voo doo 1 I am buggin out
maybe check the lug nuts or the shocks or crawl under the front of the truck and start pulling on things to see if it is loose
sans sanity
I had the splines on an output shaft go bad and it made a similar noise on bumpy roads. Give a tug on both half shafts and see if they wiggle around.
Sherdep has a point though. I make it a habit to get under there from time to time for a visual check and to push and pull on the moving parts.
1 - 3 of 3 Posts
