I just bought a '98 durango not running. I back tracked fromthe plugs, to the distributer. I made sure the shaft was turning. then proceeded to the coil. I found the casing on the coil cracked in several places. I replaced it. I tested the wire connected to the coil. There is no power getting to the coil. I checked the wiring harness all the way back to the fuse panel. I didn't find anything wrong. Now I am lost. Any suggestions................:huh:
