I just purchased a 2000 Dodge Ram 1500 the reverse is out on it will not engage all other gears work just not reverse if I put it in neutral it feels as if the rear brakes are locked when trying to physically push it the tires on rear are locked up as if hand break is locked up the only way to move it in neutral or in Reverse is to lift the rear end up and pull it why is this and how do I fix it
2008 Ram Bighorn
A trip to a tranny shop is in order, could be the reverse band needs adjusted or be broken or just something simple as the linkage needs adjusted.
Pull the pan , or have somone pull the pan off, look for the strut metal piece fell out and its laying in the pan, pretty common on these ive seen, valve body must come down to put it back in , not real hard just takes time.
