I have a 98 dodge ram 4x4..Overdrive doesnt work at all. the light doesn't even light up in the dash. I've checked all the fuses and relays. But when I checked the o/d switch itself I wasnt getting any power..
Discussion Starter · #2 ·
just a update.. I got my o/d light to work in the dash..but overdrive still doesnt work. which solenoid or sensor do i need to replace first to try and get my overdrive working.47re tranny,98 dodge ram 4x4
Transmission Man!
You need a scan tool hooked up to it to see if the computer is commanding it to shift to OD or not.
what kind of scan tool will read tranny and engine codes..I went to autozone and had them to scan it with there tool and got a p0735 and a p1388. not sure if that tells anything or not. thank you for your reply
does any one know where there is a dit on replacing ther valve body switches, and also where would be a good place to buy them. If i have to drop my pan again i'm goin to swap them all out. LOL
Transmission Man!
P0735 Gear Ratio Error in 4th Prime Never seen that code before. :rolleyes:
P1388 ASD Relay Control Circuit Automatic Shut Down Relay,not sure of this one either.
Transmission Man!
I doubt that it is the problem. You don't have codes for them any way. Why do you want to change the solenoids?
You need to go back to this: "You need a scan tool hooked up to it to see if the computer is commanding it to shift to OD or not. "
You need to watch the DATA (info),not just check it for codes.
Discussion Starter · #8 ·
i was just going to replace all of them while i had the pan down,none of them have ever been replaced,i appreciate your replies. I will work on a scan tool tomorrow and give you a update..
