1 - 6 of 6 Posts
A while back I went to the store to pick up a fuel filter, since it was about time. After not finding a filter, and a little research/questions at the dealer I found out that there is NO filter on our Durango, only a sock in the tank?
Who the hell thought this one up? Since when does a vehicle not need a REPLACEABLE fuel filter?
To further prove why I believe a fuel filter is needed, our D developed a cold-start hesitation. Once it was warm it was fine, but when cold-started, it would hesitate pretty badly if you tapped the gas pedal from idle.
I took it into a dealer to get looked at for some other things and mentioned this problem. Their diagnosis: HEY wouldn't you know..."the fuel system needs cleaning". This isn't covered by warranty, and they wanted $130 to do it. I ran a can of Sea Foam through it instead and that seemed to clear it up a bit.
This is the most retarded thing I've ever seen. Our vehicle has never seen any serious off-road duty, or even gravel roads for that matter.
So now I'm in the hunt for a good in-line fuel filter. Got any idears?
Backwoods Hillbilly
An inline fuel filter isn't a bad idea, but it's not going to help one in your fuel tank that isn't delivering correctly.
Run some more Seafoam through. It *will* take care of it, but you may need more than one treatment.
WORLD'S GREATEST TRUCK
Nice dealer you got there, maybe show him this...
Thanks for the input guys, and the picture/write-up Paul. :)
1 - 6 of 6 Posts
