Its going to give you faster shifts even on the 87 tune, so yes there will be a gain.will there be any more gain from a programmer with an 87 tune, or will it be like its not even there? I just baught a superchips programmer, and have already used the nitrous plenty of times, just wondering if it will make me faster with juice?
If running the Predator with N20, it is a good idea to pull a few degrees of timing at WOT to account for the HEMIs less than stellar piston strength.
No need to use the 87 tune, as you can pull as much timing from the 93 tune as needed, and still have all of the off idle/non WOT performance you expect from the tune.
Thanks
Mike
Last word I heard from Hemifever is he didn't want to tune for the predator until Diablo Sport gets their chit together.I'm only writing this to keep it on top, cause I don't know squat about No2, "hemifever", is doing custom tunes, a 150 shot is about the most you want to run from what I've read, and I think I also read you want to run the 87 caned tune, if you run any canned tune, I wouldn't, timing advance is not a good thing with nitrous. I'd talk to hemifever before I put the juice to Er'. :SPIN:
