First time purchase of a Dodge/ Mopar line.
'94 Dodge Dakota Sport, 4WD, 5.2L. Purchased at what I thought at the time to be a good deal and would make a good project vehicle to work with and restore to my taste.
It has turned into a money hungry, time consuming vacuum that has yet to stop...and I haven't even been able to drive it yet!!!
Things done so far include; repaired and traced multiple electrical splices incorrectly done, replaced ECM, replaced fuel pump, changed sparkplugs, cap & rotor (wires tested for resistance and confirmed new), Changed all fluids, and have just finished replacing the timing chain that turned into having to reposition the cam with chain off (it was 180 off TDC as was the distributor) After triple checking to make sure everything was as should be at TDC, I now have a CRANK / NO START with spark at the plugs and good fuel pressure on the fuel rail.
Maybe my frustration is causing me to overlook something simple (I can only hope), but I would GREATLY appreciate any help/advice I can get at this point.
