This is something I did today after work. It can easily be removed if I change my mind. Thoughts. I will get a better pic tomorrow. It was already dark when I put them on.
I guess I can't help you out then. If you click on the pic it gives you quite a large version to look at. I see it plain as day, even at night. You know how normally the bottom three inserts below the grill are black, well they have mesh there now.
There was a seller on e-bay selling all different styles of mesh in long sections of it. I just cut it with scissors to the proper size, and hot glued it with some good glue along each side and in a few other spots. It is holding real well, and you can hardly see the glue since it is clear. It comes off easy enough with a tug if I change my mind. If you are interested I can post sellers link.
I did the upper portion. I will take some daylight pics tomorrow. During the day you cannot see thru the mesh as well (like the flash exaggerates). Thoughts?
When you look at the first pic in this post of your Avenger (with the mesh just in the lower portion of the bumper) compared to the most recent picture here... Makes a big dfference. Looks great! Good job! Can you PM me the info of where you got the mesh stuff? I"m interested in doing something to my grille also.
Yeah, I almost bought that, but decided to go the cheaper route. I can always change my mind I guess. I like the mesh for now. Below is the store I bought the mesh from. Look at the different styles. I bought 9' of it and it was just the right amount. The stuff cuts easily with scissors. The upper portions are trickier with the curves and all, but it is not too bad. I bought some real good glue for the hot glue gun and tacked it on to start. Then added a line along each side, and added more small tacks as needed. Just try not to use too much, and watch for the strings of glue when you pull the gun away. The strings d come off very easy though, so don't worry if you get some on your car. You can get some better quality stuff, obviously, I just got this cheaper stuff to see if I would even like it, and turns out it looks pretty good and seems like it should last pretty good.
So you just tacked it on over the current plastic "grille"? I'm kinda curious about the longevity of this homemade project. Especially washing your car I would think it could tear away very easily. Great job though. Looks as though the cold has started up in your area as well. Poor Avengers
Yes, it is over the existing grille. I hand wash my car, so I am not worried about that scenario, and this stuff is very securely on there anyways. It is not just tacked, but each side has a complete bead of glue behind the mesh attaching it. I am still going to keep an eye on it to check on how it is holding up.
