hi there. first time to the forum. browsing the articles it looks like there is a lot to learn here!
i have a 99 durango 4x4 and it has developed a somewhat random clunking sound in the front suspension somewhere. it happens in 2wd and sounds like someone is hitting the floor pan with a broom stick. it happens at almost all speeds and sometimes happens on perfectly flat pavement going straight. i had a similar sound 2 years ago and i had the upper ball joints replaced then. for a while the sound went away but it is now back and the upper ball joints look fine and have no strange movement. the shop says the lower ball joints are a little loose but nothing major and want about $500 for the parts and labor for the replacement and alignment. any ideas on anything else to check before i drop that kind of cash?
thanks in advance!
i hear this everynow and then as well, i first noticed it 2 years ago when i first did my t/s lift, i never could track it down but doesnt seem to be too serious
ok, just heard from the shop and now they are saying the lca bushings are gone too and the whole assembly needs to be replaced. :IDEA:if this is what i can expect from oem parts i need an upgrade! any suggestions on LCA replacements that are better than the stock for bushings and ball joints?:help:
It doesn't need a Hemi
I replaced mine with urethane bushings by Energy Suspension. You usually can not go wrong with Moog ball joints and tie rod ends.
