I am a Chevy man but I got a 93 Dodge Intrepid to fix up. But I got a rubber hose that keeps melting. It comes from the right valve cover normally where you would find a pvc instead it is a stub up. And it wrapps around the back of the engine to the air intake. Does anyone know what this hose piece is call I don't know autozone, advance auto people, pepboys. No ones knows what that peice is called.
Do It In A Van
I'd say it's just a crankcase breather tube. I'd just buy some generic rubber hose and reroute it away from the heat. That seems easiest.
You would think but the way it is setup right now is probally the less heat. Would tacking a piece of pipe instead of rubber work better. I don't know. Any input would be great.
Do It In A Van
Hmmmm, that could work. How about some Schedule 40 PVC pipe? The gray kind....electrical conduit.
I had to replace mine on my 93' with a 3.3. I got it for a few dollars from my local dealer. Where is yours melting? If it is on the back side of the engine I might check the EGR valve and or EGR valve gasket for leaking exhaust gasses..........good luck!
