1 - 3 of 3 Posts
Hi all, I'm new owner of 2014 Ram, first time for me. Bought this Ram mainly to tow horse trailer, has 5.7 with 8 speed trans, 3.92 rear all the bells and whistles. But, I discovered that it also has a non stock exhaust system. Yes it sounded good when I bought it so I knew it was not stock. But I did not expect to find it also has headers with cats and 3 inch pipe into a low restriction muffler. The problem is it sets the check engine light after a couple of drives. No, it did not set when I test drove but yes it did when I drove home. Codes were P0052, P0053. I replaced both upstream sensors and after two trips it set P2098. so I purchased a downstream sensor. before I could install it, about two days later, it set P0053 again. I assume this is all due to the headers and big pipes. Has anyone made a similar exhaust mod and is there a solution?
Thanks for any suggestions.
First time Ram owner
ramboxer
You will need to get O2 simulators on it before the PCM will be happy, new sensors wont work it need to see a difference between the front sensors and the rear sensor stream of exhaust,the CATS might be the low restriction type and pass a lot of exhaust, causing the light, google O2 simulators
1 - 3 of 3 Posts
