Review from modesto83:
1st step Remove bumper
Pre Heat oven to 215 deg and bake headlights for 9 min
Open headlights
Lens completely off
Test fit your halo rings
I taped up wires with black electrical tape for a clean look.
Poke hole and run wires thru here.
Remove adhesive backing and place rings
Bake headlights for again at 215 deg for 9 min, then re assemble.
I wired mine directly to the corner lights. Brown wire is power, and black wire is ground.
First pictures
This was not a difficult install at all. The hardest part of the install was removing the bumper and re-installing it.
The rings are so bright and you really don't see any gap between the leds like the older style halos. Over all I was really impressed with the fit and function.
Thanks again AAC!
