1 - 6 of 6 Posts
Help anybody know where the gray wire goes from the + side of the coil? I'm not getting to it and I don't want to tear the wiring harness apart to find it. I put a new ignition switch on the column and a new fuel pump relay in it. It doesn't get power to the fuel pump. The truck sat for 13 years. I ran a jumper wire from the batt. To the coil and put gas in it and drove it home. But can't figure out why I don't get power to the fuel pump without the jumper wire. And I ck. All the fuseable links and there all good so are all the fuse's. I'm at at lose as where to go next.
some more info on the truck would be nice like what year it is. the only thing i can suggest is to check asd relay
Registered MOPAR User
Not sure where it is on the 1st gen ram, But that is what I was going to mention. I heard these are the larger relay in power distro center
Discussion Starter #6
Well I fixed it. The rod from the key to the ignition switch wasn't seated all the way into the switch. And now it starts and runs.
1 - 6 of 6 Posts
