~7" lift
current have 37x12.5x17 tires.
want to move to a 20" rim.
i was told i need new control arms?
They call me Fred???
You shouldn't need new control arms with 20's if the 17's fit. Usually the larger rim gives you more clearance. Might wanna ask for clarification as to why!
said something about needing to move the wheels forward to avoid rubbing. the current setup has a little rub but not enough to warrant spending a ton of cash.
If you have 7" of lift then you probably already have new control arms. Look and see if they are tubular if so they are aftermarket
Discussion Starter #5
they appear to be stock.
suggestions on good set to buy?
