This is my first post on here, so I'm sorry if this has already been covered. If it has, then please direct me to the thread.
I have recently purchased an Iron Cross HD Bumper for my 2010 Ram 1500 2wd ST Quad Cab, but once I installed it, I noticed that the suspension was quite a bit different and it feels a little over loaded. I have a 3" front 2" rear leveling kit installed on there as well.
I have been looking for heavier duty coil springs for the front, but I have been having a hard time figuring out coil spring rates or anything else. The best I have come up with is replacing the OEM progressive rate coils for a set of Rancho 4" lift single rate coils and thus trying to find a set of Shocks to fit and get a set of extended brake lines.
I guess I have the following questions:
1) Does anyone have a link to a coil spring rate chart?
2) Can I swap out some 2500 coil springs on my 1500?
3) Can I swap out for a pair off of another vehicle? (like they do w/ Jeeps swapping for Crown Vic Coils)
4) Has anyone had a similar issue and how did you fix it?
5) If my best bet is the Rancho coils, then what would be the best shocks to accompany them?
Thank you for any help.
