(D is an '02 4.7L SLT)
A couple days ago I had the original rotors and pads replaced with a set of Brembo sport drilled rotors and Hawk HPS pads (a huge improvement) and I noticed yesterday that all three brake lights do not come on when the pedal is pressed.
My brake lights worked fine prior to the new installation. I'm not completely sure they worked when I picked up the truck, because my girlfriend may have mistaken the brake lights with the standard rear running lights when I asked her to see if they operated. Anyways, I didn't think anything of it until I noticed they weren't working as of yesterday. The brakes themselves work great.
I checked the switch on the brake pedal and it wasn't stuck and seems to mechanically work fine.
I checked the fuse box on the side of the dash and didn't see anything for the brake lights. Same thing with the fuze box under the hood.
Since all three lights don't come on, I assume it's not the bulbs.
Is there a sensor on the brake assembly that may have not been reattached?
Has anyone else had this problem and/or know of a solution? Hopefully, it's an easy fix so I don't have to run it back to the shop.
Thanks for your help!
