Your trans should be the A500 which is an overdrive version of the small torqueflite A904.
If your truck is not a 4wd then the 904 should work but the ultimate 3 speed would be a small block A727 as found in automatic 2wd small block trucks and vans (not as common in cars). You will almost certainly have to adjust the drive shaft length with these changes.
Tranny man since 1982.
