I've had my 2000 ram sport 5.9l for about 2 years now and she's always run great and been extremely reliable. However, the past month or so now she's been acting up. About 3 weeks ago I was on my way home from work and out of nowhere she kept acting like she wanted to stall out. Once the RPM's were down around idle range, it purred like a kitten (this was all while moving... I was on the highway and couldnt pull over). As soon as I would try to step on the gas, it would spit and sputter like it wanted to stall. First I though engine, but if I put it into neutral, it would rev up just fine. So then I though transmission. So I downshifted to 2nd and it still did it... even tried first (at this point I was only doing about 10mph anyways and pissing off some drivers behind me), and it was no different. Then just as fast as it happened, it was gone and she ran perfectly fine. I had no other problems til about an hour ago when i was coming home from my friend's house. Once again she was running good and purring like a kitten and then I slow down to take a turn and all of a sudden I have no power steering... I look down and she had stalled out. I coasted into a side street and tried to restart but all it would do was make a quick fire as if it were going to start, but wouldnt. So I let it sit for about 5 min or so and tried again and it started right up and ran perfectly normal. I drove it around for about half an hour and it ran just as good as when I got it. I keep my programmer in the truck, and it didnt throw any codes either time. I am at a complete loss as to what is going on, and Im beginning to not trust her anymore but I really need to... she is my only transportation.
Here is a list of what exactly is done:
2000 Ram 1500 5.9L sport
14"x2" round air filter
Gibson sport side exhaust
superchips programmer (currently set on performance)
Now I am not 100% sure, but i believe my plenum gasket is leaking... its on the to do list. It almost sounds like I'm having a fuel deliver problem going by the sound/way its acting. Are these trucks known for having fuel filters/injectors going bad? I used 87 for about a year, but have been using 93for the past year or so. The other thing that I am partially debating is possibly my torque converter... but that was based solely on the original occurance... this past one doesnt make sense. The reason I believe I may have a t.c. issue is because if I try to do a breakstand, it will rev up to around 2500-3k without spinning the tires. With both times its happened, Im basically at a complete loss. Any other ideas on what may be going on?? Sorry for the long post, but I wanted to make sure I got you guys all the details.
Thanks in advance.
Kenny
Thanks in advance.
Kenny
