hey everyone. while under the truck the other day i noticed the following. Please see pictures. The is the front drive shaft connecting to the diff. It appears to be a leak/seal problem(im not sure what comonents there are)? The front drive shaft is the one WITH the u-joint grease fitting correct???? I haven't greased anything MYSELF yet, and I was wondering what was going on/and or if the two were related. Looks like if you greased the u-joint, the grease wouldn't be where mine is right now(that far up). The substance appears to grease (black/thick) and does not look like diff. fluid. THanks for all of the help/comments.
