Finally getting my act together on my swap to the 440. It came from a 75' Ramcharger, and had a mechanical fuel pump attached. Do I need to continue using it or can I use a block off plate? What happens if I use the block off plate - I mean I know the fuel line will run right to the carb, but am I goofing up by changing things? I will be replacing the intake and carb as well. Of course it will be going into my 67' Coronet.... Thoughts?
