Premium Member
I have 2011 DODGE AVENGER MAINSTREET 2.4L, having issues with my heat, CHANGED THE BLEND DOOR but HEAT ONLY COMES OUT ON DIVERS SIDE. CAN ANYBODY HELP?
I'm not sure it works the same on yours or not but something you can try is .... While you have the A/C on and blowing push in on the fan speed switch and hold for 10 seconds, let off and push and hold for about 6 seconds or until the yellow A/C lights start flashing. If it works like that on yours it will go through a sequence of resetting the doors and should stop at the the settings you have it on. If that doesn't work you may want to Google recalibrating heat and A/C on your particular car. Hopefully that is your problem.
