So today, i worked on my truck a little. It needed a new Ide Air control valve. I disconnected all the wiring harnesses to the TB sensors, and removed the throttle body. I removed the IAC, and replaced it. When i was assembling everything back together, i ran into a problem. As i was tightening the TB down, somehow the IAC wiring harness pinched itself under the IAC motor. I felt the rear bolts a little tight, so when i took a look around, i noticed the wireing harness under there.... well i quickly untightened the botls, and pulled the harness out. The weather seal i riped now, and the last prong is bent, and the plastic has bent a little also. It wont go into the IAC now. I went to my autoparts store, and its a dealer only part. Went to the dealer, and they could only find a 4-way engine harness. They said the whole harness needs to be replaced $500! Thats insane! he did say he wasnt sure if that was the only part available, and to come back another day when someone else could help me. So am i the only idiot who did this, or has anyone else have this problem. How do i go aout fixing this without paying $500 for a 4-way harness. I am sure crysler has to have a replacement part, or single harness. if not i was thinking of going to the junkyard, and cutting a IAC wiring harness, and splicing it into the original line. Would that work? i am going to try to see if i can straigthen the prong out to fit. Any help would be great
