If you've read my earlier Thread. I need some help. I've fixed several codes so now my D is no longer knocking and I have limited throttle response. This is where I am. I need your guidance.
Recently I changed the Intake Air Temperature Circuit High Input sensor. P0113 code is gone. I now have throttle control at first. It idles very rough. No Knocking. I can now reeve the engine for about 3 or 4 times then it acts like I'm flooding it and I loose throttle response. I have a new code now p2172="Throttle Actuator Control System - Sudden High Airflow Detected" Code P061A is still there. Could this be a Mapp sensor gone bad? If so where would I find it?
