1 - 2 of 2 Posts
New guy here, bought a used 97 Stratus, fog light switch out so stealer wants about $500 for switch & labor to install. I'd really like to bypass the switch and make the fog lights day time running lamps. My Chilton's manual sucks, doesn't even show the fog lamps. Does anyone have a detailed wiring diagram? It would be great if I could jump the switch and use the stock relay & wiring. Need some help on this one! Please? Thank you in advance. :cool:
Hackman
fogs
An auto salvage yard may have your switch cheaper, labor is all you.
For by-pass,
It would be better to use a seperate relay. Radio Shack has relays cheap.
Using an exsisting relay may overload it. Be sure to include a fuse on the supply side of the new circuit. Wiring help is on the relay package.
1 - 2 of 2 Posts
