I have a 04 2500 4x4 hemi with the stock suspension. My question is will the BFG M/T 35x12.5x17 fit. I will be mounting these on an American Eagle 187 wheel with +2 mm offset. Thanks Sean
I'm Not A Post Whore! :(
+2 mm, on a 17x8 or 17x10?
if it's a 17x8 you should be able to, and if not you'll end up spending a couple hundred bones for coil spring spacers to level it out, then they'll fit (should be done anyway imo)
My wheel is a 17x9 with the +2mm off set.
