1 - 2 of 2 Posts
Hi all. I posted a similar question over at DTW, so if this looks familiar it is me again. I had the factory tail lights shaved on by bee and a set of precision rodware LEDs similar to the line of fire lights installed in the tailgate, and now the body shop is having a hard time getting them to work.If the lights are wired to the factory leads as the instructions say, the turn signals flash about twice as fast as they should, and that third of the line of LEDs goes completely off between flashes instead of flashing brighter than the running lights. Also, if you step on the brake while the turn signal is on, the center section that should be the constant brake light flashes with the turn signal. If the lights are paralleled to the now removed factory tail lights, everything works as it should but there are no running lights. Any help or ideas would be great, as I am going down to the shop to try and help figure this out on monday. Thanks.
1 - 2 of 2 Posts
