1 - 2 of 2 Posts
I own a 2000 Ram 1500 (automatic transmission) Drove home from visiting family on the 25th. Stopped at a friend's place, and after stopping at a stop sign, the tranny stayed in 3rd gear for some reason, so I downshifted on the column and then put it back in drive. That fixed it for the last 3 blocks I had to drive. Upon leaving my friend's house, the check engine light was on from the time I started the truck until now. Since then, the tranny's been acting like it's about to crap out on me. It's been wanting to stay in lower gears, especially first. :huh:
Just checked the fault code by turning the ignition to the on position 3 times and I came up with P0720. I checked another forum (tried to link it but it wouldn't let me for some reason) and it lists the problem as this:
720 The Output Shaft Speed Sensor doesn't match the reported vehicle speed.
I'm hoping I just need a sensor and don't need to rebuild the tranny.
Any ideas or help on where to go from here would be greatly appreciated. :help:
Discussion Starter #2
Found the problem: :IDEA:
Output speed sensor
Autozone lists it as Sensor- Transmission Speed
Runs $16.99 :rck: :D
1 - 2 of 2 Posts
