:help:
I am having a problem with my brakes pads wearing out on the driver's side very rapidly... Replacing every 6000-7000 mi. I have rebuilt the calipers and changed to slotted rotors. The rotors helped a little, but still a big a problem. Can anyone help me??? Pleeeease. :help:
Do It In A Van
Try changing the brake hoses and make sure the caliper slides are lubed.
When you rebuilt the calipers, did you hone the bores to remove any burrs or rust build-up?
The calipers were actually replaced with new ones, not rebuilt (my mistake) and we did grease the slides.
Can I just flush the fluid, or do I need to replace the brake lines??
Thanks so much for your help.
Do It In A Van
I certainly won't hurt to have fresh fluid in the system.
But try changing the front brake hoses....the flexible rubber ones. Sometime they will start to collapse internally.
