So I dropped my 3rd gen from the front with springs and everything was good for about 3 weeks when all of a sudden I hear this loud popping noise coming from underneath me when I turn. If im parked turning the wheel it wont make any noise, only when im turning out in the streets driving. Has any one had a problem like this before? Any help will be appreciated thank you
I have not checked that yet but will when I replace the outer tie rod end as that had some play in it and the rubber was broken and ripped
Discussion Starter #4
Found the problem finally, turns out I never replaced the bolts that go from the frame the cabin when I removed my nerf bars, put them back on and problem went away
