Cant remember 100 percent but i think you can take the spindle off and use a biggg hammer but be careful not to do any damage.mariea said:I have a 2003 Dodge 1500 4wd. I am trying to replace the front wheel bearing hub. How do you get the 3 bolts off? I cannot seem to fit any tool to remove them?!?!
Any help would be great
TIA!
SilsHemi said:The wheel bearing hub assembly has 3 18mm headed bolts,you just need to find the right combo of socket,ratchet,and extension. IF you desire,the spindle can be removed if it makes it easier,but they can be removed with the spindle still on the truck.
