1 - 7 of 7 Posts
Does it go from front of engine to firewall or vice versa? Please provide a picture. I have a cylinder 1 misfire dont know which one it is but changed all the spark plugs anyways and didnt find out which one is having the problem since all the used plugs looks the same.
Discussion Starter #4
I change all the plugs and reset the code and a week later same code shows cyl 1 misfire. Any info on why this is and how to fix it?
NEVER DOUBT THE DEMON
check your ignition coil on that cyl, and run some good gas through your truck, that fixed mine...
For future reference, the cylinders are numbered on the intake manifold. You have to look closely, but they are there. Clean it well and it will help you find them.
1 - 7 of 7 Posts
