1 - 9 of 9 Posts
Just Call Me Oz
I am trying to figure out what valve springs to get and the proper length push rods.
My lift will be .512 the heads shaved 0.030 I want to also go with a thinner head gasket. So would I just subtract the difference from stock length ?
6.92 - stock length
- 0.030 Shaved head
- 0.010 - Difference in head gasket
= 6.88 total length ?
Just Call Me Oz
Discussion Starter #2
Valve Springs
My Lift .512
P5249464 Valve Spring - 0.400/0.525" Lift
Or
P4876062 Valve Spring - 0.480/0.600" Lift
Go with the crower springs their cheaper than the mopar springs. You don't need pushrods unless yours are bent or you are running guide plates. You need a shim kit from Crane Cams for pedestal mount rocker arms the same kit a small block ford uses.
Just Call Me Oz
Discussion Starter #4
Sweet I was just look at the shims.
I was unable to find crower springs on their site. I guess my question is would .525 for .512 a good match or should I go with a spring rated at a higher lift ?
Either will be fine. The most important thing is getting the install heights correct. www.socaldakota.com carries crower springs.
Just Call Me Oz
Discussion Starter #6
Ok so not so important as long as my range is within. I will probably just go local since springs are not that expensive to begin with.
not sure how these dodge heads are but if you mill the heads you might have to mill the intake as well . want to think out of the box oz , look into angle milling the heads .
Just Call Me Oz
The heads are already milled I will get the intake side of the head milled if they did not do it for me already. Thanks for the heads up.
Just Call Me Oz
Discussion Starter #9
How are these for springs ?
Outer Diameter 1.437
Inner Diameter 1 1.077
Inner Diameter 2 0.697
Damper YES
Seat Pressure @ Installed Height 126 lbs @ 1.650
Open Pressure and Height 326 lbs @ 1.100
Coil Bind 1.034
Maximum Net Lift w/.060" Clearance 0.556
Average Spring Rate 351 lbs/in
Crane Cams 96876-16 Set of 16 @ $114.95
1 - 9 of 9 Posts
