Doesn't sound like a an exhaust leak. If it was a lifter problem you would hear it louder at the top end. You might want to disconnect the serpentine belt off the crank to see if it makes any difference. When did it start? Was it ever low on oil?
Discussion Starter #4
It started over the weekend. The oil level is good, never any low pressure. No leaks anywhere. It goes away after a few minutes when the engine warms up. I'll check with the belt off.
