1 - 3 of 3 Posts
when im at a stop and i start to press the gas a little bit and go it like lurches and then i press the gas a little harder and it accelerated fine. any ideas?
may be a bad tps (throttle position sensor) otherwise i have no clue..good luck
Sticky Throttle Body, I Had To Take My Tb Off Cleaned With Sensors Removed, Then Use 1000 Grit Sand Paper To Cleanup The Walls Inside Tb And Cleaned Up The Edges On The Butterflys, Works Great Now.
1 - 3 of 3 Posts
