Derelict
So my engine (318, auto) was pinging and I finally got organized enough to pull the intake and fix the plenum. I ordered the Hughes kit and based on this thread about modified keggers and elk hunting I decided to cut up the intake.
I found my missing oil:
I ended up cutting out most of the divider and cut 1.5" off the runner with a recipricating saw:
While I was at it I put in a 180* thermostat, Autolite 3923 plugs, new cap, rotor, and new rerouted wires.
I use the truck mostly for towing so I did a little road trip with my trailer and there's definately a nice performance boost. Vacuum downshifting worked again and I wasn't downshifting on every little hill.
I still had the death flash to deal with so I added a Superchips MaxTuner before my hunting trip. Much better. There's a couple of big hills (10% grade) that are a good place to check the power. I picked up an entire gear on hill climbs. Before I went up in 1st at 30mph (3,000rpm) and now it's 2nd gear at 50mph. The gear change between 1st and 2nd is pretty large (2.45 to 1.45) so I definately picked up a few ponies. Now I can get a bigger trailer. :)
Looks like my intake with that oil when I did mine. How badly blown was your original plenum gasket? From the looks of it, you had a nice couple inches of gasket missing on that corner spot, almost exactly the same spot mine was gone. Was your old plate discolored from the heat on that spot?
Derelict
It was blown out between 2 bolts but otherwise looked ok. I think any discolouring comes from oil and blowby gases.
I meant the discoloring on the actualy blown spot where the gasket is missing from the edge of the pan cover. It looks like someone put a blow torch to it.
