1 - 20 of 21 Posts
Here's something I just finished up. I bought a kit from 4XInnovations and made my own brackets. This is a bolt on and I only had to drill one hole in the frame. I used 6x8 tubing for the brackets. I had it cut in 4 inch sections and then split it to make two "C" shaped brackets. These are used on the ends of each rail. For the center support I just made some "L" shaped brackets for the middle supports. The one hole you will have to drill is on the drivers side by the gas tank. I just used a jack to support the tank cause your going to have to take the straps off for access to the inside of the frame. I used a 1/2 inch carriage bolt on that one mount. I have less than $500 in this.
Premium Member
Do you plan on lifting your truck? They look to be 6 inches of the ground.. guess that works for speed bumps :)
I don't know about 1 bolt holding it on. It's got to be strong...
any more pictures?
I just did a Daystar level. Click on my gallery and you can get an idea. I really wanted these for my wife to use to get in and out more than anything. If I was going to use my truck as you use yours I would add more bracing. Just passing on a way to do things without welding to the frame. I can get some pics of the brackets if someone needs them.
Pics... You can't see it but the L shaped middle bracket does have a 3/4 inch bolt thru the frame.
Last one. I centered the inside tube under the pinch weld and the outside tube extends about 1 1/2 inched past the door.
Discussion Starter · #9 ·
It's a fourth gen but it seems most people hang on both forums so...
They call me Radio
Looks good! Do you plan on reinforcing the rails anytime in the future? They look a little weak for setting your truck on them.
How much room did you leave between the rail and pinch weld?
Not bad!
Discussion Starter · #12 ·
There is about a half an inch between the pinch weld and the tubing. I really only wanted a step. The only rocks we have down here are one's that come shipped on pallets os I wll probably never have the trucks weight on them. What I wanted was something functional and not give up too much clearance. From a distance you can't even see them which is what I was after also.
GetALittleMudOnTheTires
nice job
They call me Radio
Well rock on then! Those will definitely hold up really well over the years.
Looks really good man! Damn good job!
Discussion Starter · #16 ·
Thanks.
Discussion Starter · #20 ·
#1....I used this kit. 80" 88-95 Extended Cab Pick Up HREW $175 RS03-H. Talk to Adam there. You will need longer braces between the frame and rails. He will work with you. Cool guy.
#2....My gallery has a frony and side view.
#3...I am midway between Baton Rouge and New Orleans right off I-10. Lutcher/Gramercy area.
1 - 20 of 21 Posts
