As some of you know i have a 1977 dodge m880 or w200. It has a 318 with 51,000 original miles. It has a 727 auto trans and dana 60 rear end and dana 44 front end. The truck is ex military and has less then 100 miles oon it since i bought it in 2002. I have re wired most of it and all the lights work. Fuel temp and alt still donot. The body has dings and dents but not much rust. The frame still has the original rust proofing on it. It has no ac or pb or POWER STEERING. The whole front clip was replaced by the NPS with one off an 85. Rockers are good and floor is good
The Bad the tansfercase wines and grinds down. The tires are cracked but hold air. The motor has a tick in the rear it is a rocker arm tap i think. The transmission clunks into gear.
However it is a 1 1/4 ton pick up and a beast too.
I am asking 800$ for it or mabey i can part it out
Oh new master cylander electronic fuel pump and a non installed am fm tape radio are in it
