1 - 7 of 7 Posts
Ty
So I have a Power Programmer III and I am using the 87 octane setting. While towing up a grade, with about 3000 lbs behind, I get the load ping. (Slightly) So I read that I should go to the 3923 plugs (or similar) and do the 180 degree thermostat. So that fixes the ping, Right? Then I want to install a CD ignition system. Will the added voltage and spark bring the ping back????
Has anyone had the error code with the Mallory VI-A?
This is a 2001 1500 with the 360.
I also have the K&N FIPK and cat back from Flow Master.
EPA's Worst Nightmare
Ping is pre-ignition, and can be cause by timing to far advanced, too high of temp, lean mixture, or carbon build up in the combustion chamber. A higher voltage shouldn't cause any more ping. Go with a colder plug and try a fuel system cleaner.
Ty
Plugs should be in by weeks end. I'll give the cleaner a try. I usually use a cleaner every 10k.
I'm guessing that the timing is my issue, as the ping wasn't there prior to the power programer III. Would a timing adjustment do something with the compression, causing the ping? (I've read enough of these posts to throw words around. Just looking for education with this last question.)
Ty
GROUNDED
If i remember correctly the power programmer will cause pinging under load while towing. I dont think your supposed to tow anything with it.
CHROME
The 3923's will help. Try running mid or high octange with the PPIII set to 87 that helped me. I must note that once I got the plenuim gasket fixed I run 87 with the PPIII set to 87 and have 0 pinging. Mine started pinging once in awhile then got worse, sucked oil and then bucked and surged. Have you tried it with out the PPIII and hauling the boat?
Ty
I have towed without the HTIII for a few years without any pinging. I have the 3923 and the stat on order. Hopefully that will do the trick. I don't want to replace the plenum gasket. Thanks for you input.
1 - 7 of 7 Posts
