1 - 20 of 30 Posts
I've been looking for the OEM tow bar hooks for the front of the 1500's on eBay, they go fast there. $130 at the dealer seems like a lot, so I've been looking for a used one there.
A lot of them say they come with "three bolts at each end" but that they are not sure if that is all the mounting hardware. I dont want to save thirty bucks but then dump it at the dealer for some high-grade bolts that were missing.
Anyone know how many bolts the OEM tow hooks use to mount?
thanks
t711
2012 Texas Ram Express
i'll go and take a look for ya
from what i looked at, each hook is mounted to the bar by 2 bolts each.
There are three per side, I removed my hooks a lil while back and painted the hooks themselves. Remember on th 1500s its a complete bar with the hooks attached, the 2500/3500s have separate individual hooks.
KB
I was looking at that, too. I like the HD hooks better, plus they are more readily available and cheaper on ebay. But I think they mount on to frame members that do not exist on 1500's. Havent really looked myself, though. If someone knows, I'd like to know too.
Country Boy
YOU CANT USE 2500/3500 TOW HOOKS ON A RAM 1500. SAME GOES FOR USING 1500 ON A 25/3500. mY TOW HOOKS THAT I GOT OFF OF E BAY DID NOT COME WITH HARDWARE. ONE TRIP TO HOME DEPOT AND I WAS ALL SET. 6 BOLTS TOTAL
sorry for the bad info, i justk know my truck came with the hooks, im not expert on how they where installed at the factory, i just seen the bar, and the hooks on it, with 2 bolts holding each hook on..
Thanks and btw i was just reading a thread on DTW, where people where saying they installed the 2500 hooks on there 1500's.
i seen where one guy said he installed some, his profile says he has a 2002 1500....so, wouldnt hurt to check into it.
Shark Hunter
I have them on mine. Took about 20 minutes to do and the only thing that the instructions tell you to do that I did differently is not to undo both sides at the frame at the same time just one side at a time and no aliment problems. Will try to find instelation sheet and scan it if you want. The dealer gave me a second bar but only has the bracket to mount it for one side, thats why they gave it to me. Thought I might bolt it on the back someware.
Not much choice if you want to pull or be pulled from the front, I could find nothing strong enough on the front to hook to so went with the factory set up, warranty intact.
Rob
Shark Hunter
No reinforcement behind the bar, it must weigh 30/35 lbs and is quite a substantail piece. It looks like it is cast as one item. The hooks are not welded on they are part of the bar. It also has hollow sections I would imagine to try to keep weight down. The spare I have only has the mounting bracket for one side and they are quite complex.
The list price was $135.00 and I paid $104.50. It is a Mopar part and is marked " same as production ".
Rob
1 - 20 of 30 Posts
