1 - 2 of 2 Posts
I have a 02 Ram with the 3.9, my first problem is my passenger headlamp is filling with water and I was wondering if anyone knows an easy way to remove it. I am also noticing a slight tick sound from under the hood, could this be just an exhaust leak? Thanks for any info. JR
An easy way to remove the water or the lamp? You can take the whole light assembly off the truck using a 10mm socket and a long thin extender. That and a few plastic screws once you pop the hood.
After doing that you can try and pour the water out I guess. Then I would seal it with some black rtv silicone along the edges. Or you can go to the interior/exterior forum and read the how to on clearing headlights. :) Will explain how to remove the headlamp and take it apart. Might be best way to dry up the water and then you reseal with rtv.
KB
1 - 2 of 2 Posts
